I just recently build a new system with an i7 9700kf and an Asus rog strix z390-f mobo. But I'm having issues with the cpu throttling down to 4.2 GHz on all cores after 15 seconds or so of running Cinebench r20 (which results in a score of around 3200 compared to 3600 that others get with similar setup). The temps in the first seconds, while the cpu runs at 4.6 GHz (as it should), are fine at 61 degrees, and then when it throttles it goes down to around 45 degrees. Can anyone explain to me why this happens and if it's normal, and if not what should I do and how can I fix it? Hope somebody can help 😛
