I have been trying to fix this on my own and cannot seem to get this figured out. No matter what I try, my i9 will crank up 90-100c under 40% load. Certain games will spike it to 90, while others get it up to 80. When trying any testing it reaches 100c easily. I've tried many different solutions and I cannot figure this out. (for example, Arma 3 will cause it to reach 90-100c even when trying to offload to the GPU)
Idle temps range from 40 to 50c (high 30's when it's cold inside my house), and simply having two tabs on chrome open take it to 65c or even higher. (even with only 5% load on the CPU)
Any help here would be appreciated.
BIOS settings are all stock with MCE disabled and no XMP (with MCE and XMP it will spike up even faster)
I tried to change the core settings as I thought the voltage was too high (HWinfo reads out 1.49 vcore) at peaks. At any manual vcore setting under 1.4 my computer will not boot.
I am not super experienced with BIOS settings so I have not tinkered with too many. I have changed the fan curves to run faster at lower temps to try to counteract the temps but even this does not help (maybe 1-2c max)
Windows Power mode is set to balanced.
Setup:
CPU - i9-9900k
GPU - msi gaming x trio 3070 8gb
Mobo - Aorus Z390 pro wifi
RAM - Vengeance LPX 32gb (2x16) 3200mhz
AIO - MSI Mag Coreliqud 360r
Case: Lian Li LanCool II (with mesh front and side panel)
Airflow
Intake: 3 Noctua NF12 industrial PPC 2000 RPMs intake through the radiator; Stock Lian Li Case fan under GPU intake
Exhaust: Noctua NF-A12 exhaust at the back, two of the 3 fans that came with the MSI AIO exhaust top.
Setup:
CPU - i9-9900k
Airflow
