Thanks for your help! and yeah I am still figuring out what to do.
So here is my point of view:
I would like to use the tempered glass for the aesthetics. I have been doing measurements with the case and gpu in horizontal pos. I can fit 120x15mm fans under the gpu (aio radiator won't fit).
I would top mount the 120mm aio above the psu mounting bracket (measurements fit). for 240mm aio on the top I need to do more modification (which I don't like) because of ram clearance on mobo.
The big air coolers won't fit because of ram clearance so that's why I thought of the 120mm aio.
Fan setup: 2 120x15mm fans bottom mount, 1 120x25mm fan top mount (above mobo) and 1 120mm aio top mount (above psu bracket), 1 92x25mm fan back mounted.
Airflow:
initial idea: bottom intake, top exhaust, back exhaust.
second idea: bottom exhaust (for gpu heath), top exhaust, back intake
(have to do a little more research on aio + tempered glass panel airflow.
The idea of this build is compact aesthetics.
-Does this setup sounds decent or is it a no go?
-Why would the aio choke with the tempered glass panel?
thank you for your effort to help me again!
