ie6 Connection problems
G
Guest
Guest
Archived from groups: alt.comp.anti-virus,microsoft.public.windows.inetexplorer.ie6.browser,microsoft.public.windowsxp.help_and_support (More info?)
After a stupid error by me I cannot get IE to keep the "never dial a
connection" option.
This is what happened.
I ran a scan of the registry using REGSEEK and deleted a load of keys it
said were not used.
After this Norton AV would not work, so I reinstated the registry and
it still would not start up.
So I uninstalled Norton and installed it (3 times) until it installed ok
and auto-updated correctly.
While doing this and rebooting in safe mode 2 or 3 times all my services
got disabled! I have set these back to what I think they should be to
the best of my ability, but now whenever I reboot the internet
connections insist on resetting themselves to "dial whenever an internet
connection is not present".
Anybody any idea how to get this selection to persist after a reboot?
TIA
Steve
From: "Steve Rainbird" <steve.rainbirdxxxxx@mssint.com.removex>
| connection" option.
| said were not used.
| TIA
| Steve
It sounds like you screwed up the PC by your actions using REGSEEK and deleting keys. If
you are using WinXP then you should restore the OS using a Restore Point prior to using
REGSEEK and deleting said keys.
Dave
http://www.claymania.com/removal-trojan-adware.html
http://www.ik-cs.com/got-a-virus.htm
System Restore?
~Robear Dyer (PA Bear)
MS MVP-Windows (IE/OE, Shell/User, Security), AH-VSOP
> connection" option.
> said were not used.
> TIA
> Steve
> | connection" option.
> | said were not used.
> | TIA
> | Steve
If I had one I would! I do have a Norton Ghost backup but don't really
want to go down that route until I have exhausted other possibilities.
Steve
| Steve
I think restoring a Ghost image is your recourse if you don't have a system Restore cache
restore point that you can use.
Dave
> connection" option.
> said were not used.
> TIA
> Steve
Regseeker took a backup of the keys it deleted which I have merged back
into the registry. Its still does not work. This suggests to me that
it has nothing to do with the registry.
Any ideas?
Steve
> connection" option.
> said were not used.
> TIA
> Steve
Another question. Why does "dial whenever a network connection is not
present" not recognize a lan connection as a network connection?
Steve
