If my subwoofer has no bass control, will S/C help?
G
Guest
Guest
Hello,
I have a 2.1 speaker system from Logitech, the sub has no bass control.
So for certain music the bass is way too much even for a small sub. It is perfect for those into rap music, though. I tried playing around with the equalizer on WMP but it sounds weird.
I was wondering if I get a sound card like the X-Fi extreme if I will have control over the sub and get a generally better sound output instead of my onboard audio?
Or will it be a waste of money on a 2.1 system?
To note my motherboard has the sound chip from VIA. Speakers are the Z313.
Appreciate any advice, thanks.
Neat, I didn't know about standalone EQ programs. I googled about them and they seem interesting but is it a significant difference than integrated EQ in Windows Media Player?
Also if you have any recommendations on the top of your head I'd appreciate it. There are so many out there it seems.... I would also need something that is easy to use with preset options, I suck at setting EQ's.
Thanks for your help.
