I'm building a PC and need bluetooth and wifi
kochoa
7
So the parts are all currently being shipped and I need wifi and bluetooth. I saw a 2 in 1 wifi bluetooth card from Gigabyte (http://www.gigabyte.com/products/product-page.aspx?pid=4135#ov) and was wondering if it would work with my motherboard (I have a Sabertooth x79). And also, are there are any other bluetooth/wifi cards that would serve as another potential option?
One, like this one. Best I've had and still have. And I have tried whole bunch of them.
I wouldn't get any PCI wireless card anymore. Get instead USB, it has more power, faster reconnecting times and longer distance coverage.
I have Amped Wireless UA600 and after I got rid off my Linksys PCI card for this, What a difference that is. (I had this one and 2 others ... http://www.newegg.com/Product/Product.aspx?Item=N82E16833124342)
No more disconnections, PCI device slows down the boot time too. When I start the PC, type the password, and click on tom's HW shortcut, it is displayed in a second!
With that PCI (had 2 more to try) it started to connect after log in and it took few seconds.
Love it! My wife's iPad has about 6 networks...
Its bit weak unit. Get USB wireless adapter, its stronger, faster with dual USB connections that will ensure the strong signal reception.
Love it! My wife's iPad has about 6 networks to connect, I have about 40!
Linksys had about dozen.
Also this USB has 2 USB connections, for better strength, as it supply more power.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833281002
