Question Inno3D RTX3060 Noise & Heating Issue
May 28, 2022
4
Hi guys,
I think that there are some problems with my graphic card among the system components i have just gathered, but i wanted to consult you because i am not sure.
1- When PC is opening, the graphic card fans automaticity working for 15-20 seconds, card already cold, so i don't know why this happening.
2- When i open a game in ultra settings, the graphics card temperature can be 79-80 Celsius in about 15-20 minutes, and even 81 in the following minutes. (As i looked from the MSI program, the fans are running at 80% power at this time.)
3- Finally, i think the graphic card fan is making a lot of noise.
System: AMD Ryzen 5 5600 3.5GHZ 35MB AM4 65W + Asus PRIME B450M-K II 4400MHz (OC) AM4 mATX + Inno3D RTX3060 Twin x2 12GB 192Bit GDDR6(LHR) + Crucial Ballistix 16GB (2x8) 3200MHz DDR4 CL16 + Samsung 980 1TB SSD 3500/3000 m.2 NVMe MZ-V8V1T0BW + Aquarius-Mesh 650W 80+ Bronz RGB Mid. Tower Case + COOLER MASTER MASTERLIQUID ML240L V2 2x120mm RGB
The most likely cause is lack of airflow...
And this never seems to amaze me, you have all this nice hardware and pair it up with a bad quality PSU, I would suggest replacement!
How could all these problems be related to the PSU and which PSU would you recommend? Thanks in advance.
Here is the my case:
https://www.hizliresim.com/4gth4p7
https://www.hizliresim.com/g2gev1e
P.S: I removed cpu cooler, because case too small. I will change another case.
Umm... right now, this is what is going on at the front panel:
AIO fans -airflow> radiator | <airflow- case fans | mesh panel
Radiator fans and case fans are currently blowing at each other, instead of in the same direction... try flipping the radiator fans.
