G
Guest
Guest
Ive recently just bought a SCSI CD burner and also a SCSI card to run the burner off!. but my question is, how do i install them???. My CD drive is IDE, so i cant exactly use the SCSI cable to connect both IDE and SCSI on the same cable that would lead into both the Burner & CD drive because of the different interface connections!.. the only thing i can think of possibly doing is installing the SCSI card onto the board, then just run the SCSI cable straight from the card to the Burner!? .. would that work!. or do i need both the units connected with the 1 cable, as you would if it were from IDE to IDE ??? .. and if so!.. what should the jumper settings bee on the back of the burner ( which is 2nd hand by the way, so i have no manual )
Someone please help!
