I just bought the following components and put everythings together,
rog zenith extreme alpha
Amd Theadripper 2950x
ROG Strix GeForce® RTX 2080 Ti OC edition 11GB GDDR6
corsair dominator 3200 16gb
Samsung SSD 970 PRO NVMe M.2 512GB
nzxt x62
I tried to install windows 10 pro on my computer using a usb boot drive. When I try to start windows the blue screen with " " was shown, my cpu temperature rose to ~65 degrees according to the little screen on the motherboard.
After searching for solution the whole day I found https://forum-en.msi.com/index.php?topic=309637.0 , the solution was to upgrade Wireless-AC 9260 device and install the windows again. After that I was abddddle to start windows 10 and use it for a while but whenever I click anything the cpu temperature increases by ~10 degree C. The computer shutdown when I was installing Matlab and now the windows is not working again. I set several recovery points but it didn't work. I then updated bios and disable iommu, but still didn't work.
Please help
nzxt x62
Please help
