Re-post with Update.
=====================REPOST===============================================
I am in a similar situation, after hours of adjusting and running Prime, I have found the following results-
4.2 core / 4.0 cache required volts
1.28vcore / 1.19vcache / 1.80vinput
Heat: 80 c under full load (running Prime95 small FFT for 20 hours)
4.3 core / 4.1 cache required volts
1.32vcore / 1.19vcache / 1.80vinput
Heat: 84 c under full load (running Prime95 small FFT for 12 hours fo far)
I don't think I will ever make it to 4.4.
In case anyone is wondering, I am using an Asrock z87 Extreme4 motherboard.
=============UPDATE AS OF 04/15/14====================================
I did a fresh install of Windows 8.1 and started getting random hal.dll & ntoskrnl.exe BSOD's. After doing some research online, it would appear that these errors are related to the CPU so I went back to stress testing...
Downloading the latest Prime95 (28.4) 64bit. I ran small FFT and the temps went up to 100c straight away!
I immediately stopped the test and went down to my 4.2 settings, same result - straight up to 100c. I then downloaded a previous version (25.11) and ran small FFT and the temps were barely hitting 80c. Going back and forth between the two I tried doing a blend on the latest and got instant BSOD and then went to 25.11 and ran blend, but crashed after an hour or so. So now I am thinking I am back to square one in terms of being stable.
Doing a bit of reading this morning, I hear a lot of people are losing their OC when moving to Windows 8.1... I am going to spend some time tonight trying to dial it back in, but wanted to see if anyone else has this issue and has any recommendations?
