airplanegeek
i5-4670K stable 4.6GHz 1.256 Vcore, 2.15 VRIN, havent messed with cache yet. Thermaltake Water 2.0 Extreme. Max temps low 90s on IBT. But im only getting 120GFLOPS
I was able to run IBT on high for 10 runs successfully, but my CPU temps are hitting 90-100 degrees on 100% load (no throttling) is that too high? It idles at 30 degrees
Asrock Z87E-ITX
i4670k
Corsair h80i
CPU multiplier: 44
CPU cache ratio: 30
CPU Vcore: 1.32 (lowest it could be to achieve stability)
CPU cache voltage: 1.25
CPU input voltage: 1.9
Anything I'm doing wrong?
Does that mean I have a below average chip then? :\
Thanks Yogi, I bumped back up to 4.4 GHz and only hit 60C while gaming. It looks like I should be safe there.
