CPU-Z TXT Report
Binaries
CPU-Z version 1.68.0.x64
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.320 MHz
Sys timer 1.000 KHz
BCLK timer 99.98 MHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 4670K
Codename Haswell
Specification Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 84 Watts
Tjmax 100.0 °C
Core Speed 799.8 MHz
Multiplier x Bus Speed 8.0 x 100.0 MHz
Stock frequency 3400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 34x
Max turbo ratio 44x
Max efficiency ratio 8x
O/C bins unlimited
Ratio 1 core 44x
Ratio 2 cores 44x
Ratio 3 cores 44x
Ratio 4 cores 44x
TSC 3400.2 MHz
APERF 2300.0 MHz
IA Voltage Mode Override
IA Voltage Target 1280 mV
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode Override
LLC/Ring Voltage Target 1229 mV
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
