Intel Management Engine Components fails to install?
WhitePonyNZ
30
Hi guys,
Just a few days ago I put together my new build. Everything has gone off without a hitch except for the inability to install one of the drivers that came with my motherboard, which is the Intel Management Engine Components.
I have tried two versions of the driver, the first on the disc that came with my motherboard, and the other from the Gigabyte website.
After choosing the install location (left at default) and clicking next, the install process begins for half a second or so, until I get an error which reads:
"The set up program ended prematurely because of the following error: Fatal error during installation."
I have ran the installer normally, and also as an administrator. Both versions of the driver have exactly the same area.
The motherboard is a Gigabyte GA-H170-HD3, with a Core i5 6600, running Windows 10 Home 64 Bit.
Thanks in advance for any help :)
Hello... GOOD to GO!!! No worries... have some FUN... Good JOB! B )
I Think WIN 10 media had the intel driver loaded in it already for that hardware, is WHY the driver install would error.
Thanks for your replies. I have installed that driver already. Or would I need to reformat, then install INF, then install IMEC?
Thanks again.
I have opened my device manager and no items appear yellow or red? I will try upload a picture very shortly :)
So if i'm reading this correctly, the driver is actually already installed? Should I reformat and try again just in case, or am I good to go? Thanks alot :)
Hallo,
I have a little bit the same problem. I can't install the Management Engine Interface either the INF installation. I have the Asus B85m-e motherboard.
I think i have finaly installed MEI but when i try to install INF get this message . it's in greek language
Pleaze i need help
i had the same problem and, holy cow, i read through the comments and checked my device manager to also find that the MEI was already installed on my computer. what the puddle ducks? i just built this darn thing, how could it already be installed!? weird. thanks for the solution! 😀
Because, the bandwidth hogging capabilities of Microsoft Windows have been upscaled tp 100% which download every single driver on it's own.. Destabilizing many other applications..
