Hi,
im running a pentium g4560 with a stock intel fan, but when i boot the system up the cpu fan does not run. The system boots and works fine running around 55 celsius without the fan running but worried it will be worse if i try running a game. Previously i have noticed the fan running constantly. i tried changing the fan header to a different slot on the motherboard and still no luck, ive also looked into the bios settings, changing the fan speed to max but still shows no change and 0 rpm. Is this normal behaviour and the fan will ramp up as the temps increase or do i have a problem here as everything else is functioning fine? if so is there anything i can do?
