Nobody noticed this, but check this out:
http://download.intel.com/design/processor/datashts/31327801.pdf
Go to page 78 of the datasheet. Take a look at Extended HALT power.
Every Core 2 Duo CPU is at 22.0W, EXCEPT the E6700, which is at 20.0W. This is not a typo. This is binning by power consumption. Charlie(Inquirer) mentioned that Core 2 Duo are binned by power consumption, which meant highest end CPU consumes LESS power. People may then wonder why is not the X6800 that consumes least power since its the top-end. I'd say the explanation is that X6800 is a more performance oriented part, while E6700 is the highest mainstream. You can see in measurements its actually true, E6300/E6400 consumes more power than its 4MB cache, higher clocked brothers!!: http://www.xbitlabs.com/articles/cpu/display/core2duo-shootout_11.html
It's true in idle that higher end CPUs consume less power. It's different in load and takes a different turn.
However, I would say it depends on the application. Due to the advanced power management of the Core 2 Duo CPUs, there will be a case where 4MB parts are going to consume less power than the 2MB parts in some cases even if peak power measurements indicate otherwise, since 4MB parts can finish the task quicker and go to idle mode.
