I had a problem restarting my pc this weekend. Components are as follows:
Gigabyte P35 DS3R
e6750
Seagate 400 Gig HD
Windows XP Pro
XFX GS7600 Vid Card (until new card gets here)
Benq 1640 DVD
Samsung 203b DVD
2 Gigs Corsair XMS2
Ultra XF600
AC Freezer Pro 7
Antec Midtower case
This system was built 2 months ago and has been running flawlessly. I did not install any new hardware or software recently. The PC stay on 24/7 so I have only turned it off for updated or occasional reboots.
Tried to reboot on Sunday and the fans started but nothing else. No post beep, no flashing lights on keyboard. After about 20 tries the system started. The system stayed on for 2 days at which time I had to reboot for a Norton update. This time it would not restart. Only fans would go on.
Wed. I checked all conections, removed and checked ram, made sure everything was seated, reset bios, changed out power supply. Still same conditions. Upon calling Gigabyte tech support they said to remove cooler and start pc to see if processor was getting warm to determin if processor was good. To check this I had layed the box on its side so the mb was laying flat. Process gets warm so it is good. But as soon as I put my finger on processor I got a post beep. So, as per tech suggestions, I removed and reset processor and after getting things booted went into cmos and upped the ram voltage by 0.02 ( which really did not make a difference). Next restart same problem. But I realized the real problem was that when the cooler (which is very light) is installed it slightly pulls down or distorts the mb and stops the pc from booting. If I apply slight pressure upward on cooler all is good. Tech suggests that I rebuild out of box to confirm that I do not have a short, but building out of box I would be laying mb down and at that point everything works fine. It is only when the box is standing normally that the conditions exist. Also if I had a short wouln't the pc recycle? Which it has never done. My opinion is that the mb has a defect that is only seen when pressure is applied to board in a normal way. For now I have just pushed up on the cooler a little and the box starts and stays on fine. Any comments?
Gigabyte P35 DS3R
e6750
Seagate 400 Gig HD
Windows XP Pro
Benq 1640 DVD
Samsung 203b DVD
2 Gigs Corsair XMS2
Ultra XF600
AC Freezer Pro 7
Antec Midtower case
