For the last few months I have been experiences intermittent connection issues on my home network and I need more ideas to try and test to see what the problem is. I am coming for help!
ISP: Spectrum (I know... but they're my only option)
Internet type: Cable internet
Modem: Spectrum Modem
Main router: Netgear RAXE300
Access point router 1: Asus RT-AX55
Access point router 2: Netgear R6700AX
A few months ago I started experiencing this issue out of nowhere. I play online games, and before this all started I was receiving good connection speeds and low ping.
All of a sudden I noticed my ping would increase in Game to almost an usable point at random intervals. Things would be good sometimes, and then at night I would randomly spike and disconnect intermittently. I first had spectrum come out and they replaced the main modem cable as they said the old one was faulty. This did not solve the issue.
I started looking into why my network might be failing inside the house. At the time I had all devices on one spectrum provided router (60 devices total including ethernet devices). This was obviously an issue! I started to address this problem about a week ago.
I replaced the spectrum router for something more beefy, and bought a few other small routers to help break up the load for my IOT devices around the house. I have since segmented my network by using 3 routers to properly space out my devices. Segmented bands so that my many IOT devices were on different routers and on the 2.4GHz band. I limited the amount of bandwidth the router was allowed to send on those bands. I left all my large devices connected to ethernet cables run through the house. I am also constantly monitoring what devices are connected on the network and do not see any weird devices taking up large percentages of bandwidth. If there is a device causing this issue, I am not skilled enough to find it.
No one router has more than the specified "Allowable devices" on it now. They all have less than 20 wireless devices connected to them.
For my PC (The device I ran the test I am about to share, I have it connected like this.) I will mention that the device is connected all the way through ethernet (CAT6 cable and above)
Main Router -> Ethernet (AP Router 1) -> Ethernet (PC)
From my PC I kept up a ping test back to the original router to ensure there wasn't a problem internally reaching the main router. I have never seen it drop below 1ms during my ping test.
To test my connection to the outside world I ran a constant ping test against www.google.com and www.facebook.com and found there is an issue. During certain times of the day, SOMETIMES, my connection will very drastically. From 20ms all the way up to 300ms.
Example: 24ms, 30ms, 40ms, 26ms, 60ms, 24ms, 160ms, 44ms, 26ms, 221ms, 266ms, 28ms, 35ms, 24ms, 118ms. <---- It spikes for one or two packets, but consistently. Definitely enough to momentarily disconnect me from any online game I'm trying to play.
My ISP will run connection test from their side and say "Hey speed test came back okay so there isn't an issue!" And yes the speed test generally come out okay, but it's the latency issues that are causing all my problems and it's like they don't know what that means. Also the fact that it works sometimes and not others really makes me suspicious that it's not my internal network.
I am going to buy an Ethernet cable tester to make sure that my cables are causing the random spikes between the Main Router and Modem, but past that I'm all out of ideas of how to figure out if anything on my side is causing the issue. I will post a screenshot of the ping test I ran to google where you can see what was happening. It also has my internal network speed test to verify that there is no issue reaching the router.
Please help! I am out of ideas and will take the time to understand and learn anything anyone would like to help with!
Thanks,
-An annoyed gamer
Thanks,
-An annoyed gamer
