Question Internet speed while using powerline
Apr 22, 2019
Greetings. I recently started using Powerline Adapters, since I can't connect my router to my computer directly. It works fine, but there's a problem: whenever I leave my computer turned off for a few hours, the internet download and upload speeds go down massively, and my ping is capped at 60. I have to restart the adapters for the speed to go up again, and for the ping to go down to 12. This is really annoying since I have to restart the adapters everytime I turn on my computer or whenever I want to play online.
digitalgriffin
387
54
18,870
It is likely they are going into powersave mode due to lack of traffic. It takes a while for them to "wake up" hence your ping issue.
If they are using the Qualcomm QCA75090 Powerline /Atheros LAN chipset, you can use any number of utilities to turn off the power save feature.
If they are using the Qualcomm QCA75090 chipset, you can use any number of utilities to turn off the power save feature.
I'm kind of a noob in these things. I'm using the TP-Link AV600 adapters, can you tell me how can I disable the powersave mode?
