[SOLVED] irql not less or equal stuck 0%
Jun 29, 2021
its been 30 minutes and the blue screen is stuck at 0 percent with stop code irql not less or equal, i was just done playing valorant when i quit the game the blue screen appears. what do i do?
do you have any other anti cheat programs on PC? It seems Vanguard doesn't like them and will crash once you shut game down
Can you follow option one on the following link - here - and then do this step below: Small memory dumps - Have Windows Create a Small Memory Dump (Minidump) on BSOD - that creates a file in c windows/minidump after the next BSOD
  1. Open Windows File Explore
  2. Navigate to C:\Windows\Minidump
  3. Copy the mini-dump files out onto your Desktop
  4. Do not use Winzip, use the built in facility in Windows
  5. Select those files on your Desktop, right click them and choose 'Send to' - Compressed (zipped) folder
  6. Upload the zip file to the Cloud (OneDrive, DropBox . . . etc.)
  7. Then post a link here to...
  7. Then post a link here to the zip file, so we can take a look for you . . .
just in case it happens again.
