It is a REALLY old psu. Not sure about the model, gotta check that tomorrow. But does it really matter? Is there any drawback of using older power supply?The 9800gt reccomends a 400w minimum, so wattage should be fine.
Is this a decent 400w psu? What is the make and model.
I will just use the adapter. I am just wondering if the 400W is enough for BOTH gpu and cpu.9800GT specs
Recommended power supply for the 9800GT is a 400 watt PSU, but if your power supply does not have the required PCI-E power ports, it should not be used with that graphics card.
-Wolf sends
SATA or MOLEX to PCIE adapters are not reccomended. SATA and Molex are not designed to provide the required amperage for a PCIe connector. This can result in PSU failure and/or melted wire/adapter.I will just use the adapter. I am just wondering if the 400W is enough for BOTH gpu and cpu.
Could fail and kill your hardware. It may be a decent unit tho.But does it really matter? Is there any drawback of using older power supply?
The thing is that I am using it right now, with an adapter. It works perfectly fine. What am I trying to do is upgrade my cpu to core 2 quad. That is why I am asking if the 400W psu enough.SATA or MOLEX to PCIE adapters are not reccomended. SATA and Molex are not designed to provide the required amperage for a PCIe connector. This can result in PSU failure and/or melted wire/adapter.
If it doesn't have the required connectors you cannot use it.
Just because it works now doesnt mean it will continue to work.The thing is that I am using it right now, with an adapter. It works perfectly fine. What am I trying to do is upgrade my cpu to core 2 quad. That is why I am asking if the 400W psu enough.
ok...Just because it works now doesnt mean it will continue to work.
I would definately upgrade the psu before putting more stress on it.
I will check tomorrow.But which PSU model and brand is it exactly ?
I can guarantee that the hardware in my pc is older than that one. My pc worked for almost 10 years now... and guess what.. it worked "perfectly fine".For what it's worth, this PC worked "perfectly fine" for a number of weeks before it was no longer "perfectly fine".
You really do like to bring negativity. Is it that hard to say: "No you can not" or "Yes you can".Isn't that how things typically work?
They work "perfectly fine" until they don't.
A car works "perfectly fine" until you run it into a building.
You want to wait to start a fire or destroy your hardware before you can stop saying it works "perfectly fine"?
Well then, how do I "treat" my power supply?You can run a car and never change the oil.
It might work for years, but eventually oil passages get clogged and you engine will explode, costing more than just changing the oil in the firts place
Got it,You stop using it as soon as you can and get something appropriate.
What happened there?For what it's worth, this PC worked "perfectly fine" for a number of weeks before it was no longer "perfectly fine".
Its ok if it fails. i am concerned about the fire...Just like oil changes cost less than an engine replacement, getting a better PSU now will cost less than a new PSU and other hardware replacements when your current PSU fails.
It will fail, its just a matter of time.
