CreedMaster Reputable Dec 2, 2015 62 0 4,630 Dec 1, 2016 #1 Like it says will my power supply be enough(The power supply is bronze certified). I am not thinking of overclocking and I got the numbers from http://outervision.com/power-supply-calculator on expert.
Solution Dark Lord of Tech Dec 1, 2016 You will need more power to run both. I just assumed you were upgrading the 960 to the 1060 , you will need just a little more power.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Dec 1, 2016 #2 What are your specs? Calculators are a poor judge of power needs. Upvote 0 Downvote
CreedMaster Reputable Dec 2, 2015 62 0 4,630 Dec 1, 2016 #3 What are your specs? Calculators are a poor judge of power needs. I7 6700k 4.0 GHz 16 GB DDR4 Z170-E Motherboard 1 TB SSHD 2 TB HHD GTX 960 4gb GTX 1060 3gb EVGA 500 watt 80 PLUS Bronze certified And yes I have two different gpus one for physx because overkill Upvote 0 Downvote
CreedMaster Reputable Dec 2, 2015 62 0 4,630 Dec 1, 2016 #4 EVGA 500 watt 80 PLUS Bronze certified , yes it can easily power your specs. Sorry but umm I'd like to see some support..... I'm a little on edge right now just want the desktop to work :/ Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Dec 1, 2016 #5 My bad I missed your 960 , I thought you were upgrading to a 1060. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Dec 1, 2016 #6 The 500w EVGA isn't enough to power both cards. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,872 159,590 Dec 1, 2016 Solution #7 You will need more power to run both. I just assumed you were upgrading the 960 to the 1060 , you will need just a little more power. Upvote 0 Downvote Solution
