Hello.
My laptop is Asus TUF FX705DY. My GPU fan has a loud grinding noise. I opened and checked it. It was a bit loose and I think that's why it makes that sound. Because I completely cleaned it and the other fan fits perfectly and doesn't move when I turn it upside down. So I thought, I should get a replacement part and change that fan. I looked on eBay, Aliexpress and overall Googled it. There were fans of FX705DT, DU, GE, GM, etc. Every model except mine for 15-30 dollars. I found a fan for mine, but it was 80 dollars. Then I saw that the list of compatibility on 80$ fan included FX705DT. Which was also compatible with 15 dollar fan. Now, my question is, will FX705DTs fan be compatible with my laptop? I think it will, but I wanted to be sure.
Thanks for reading.
Thanks for reading.
