Question Is it okay to use one pigtail PCIE cable to power a 350w card?
Hi, reading conflicting reports that you need two seperate PCIE cables to power two 8 pins on an RTX 3080, I have a decent power supply in an Rm750x (2018).
Anything to worry about?
Image of 3080 with singular cable for reference: View: https://imgur.com/a/NjPr7sV
I looked in the manual and it had no watts listed for a single cable.
My Seasonic said 250 watts per cable.
It could very depending on wire length and gauge.
I would use 2 separate cables to be on the safe side.
Reactions: MINIRED
