[SOLVED] Is it safe to have cabinet fan and gpu fans blowing air into each other?
Priyam Mukherjee
I have a Frontech Fender 4208 cabinet which has 3 led fans. One of the fans is located on the rear top which sucks air inside the cabinet and the other two fans are present above the Psu shroud which also sucks air inside the cabinet. Now the problem is i have a gpu, Gigabyte gtx 1060 (dual fan) which is directly placed above the two fans of the cabinet. And hence the gpu fans blows air towards the cabinet fans and the cabinet fans blows air towards the gpu fans. Is this set-up safe? Will it cause any problem?? If yes what should be the solution?
I've done similar things to this and never had a problem.
I would set it up the way you want it and then run the GPU hard and check the GPU temp....but I think you will find that it's OK.
