Is it safe to just disconnect my ruddering case fan? Case fan recommendations?
frosche
Commendable
May 6, 2018
9
So I'm almost positive that my case fan is shot. There's this annoying small screeching sound to suggest it's because of the bearings. I went in to inspect and I saw hair in the middle of the fan. Guess I shouldn't be surprised as my PC has been an expensive vacuum cleaner over the years since I put my tower on the floor as I have no space elsewhere. Is it safe to just disconnect this specific case fan (I have 3 in total) and this one is in my front until my replacement fans come in what I can hope is 2 days (amazon prime)? Would you suggest I stop gaming during this time if that's a yes? (I'm talking game intensive like Dying Light or R6Siege)
Any suggestions on any fans you guys would recommend?
I know specs play a role into the amount of case fans you should get so here are mine
Graphics Card : GTX 980
CPU : i7 4790k
Case : Rosewill Stryker M ATX Mid Tower
Resolution : 1920 x 1080
Please feel free to ask me any more questions if I'm missing anything.
Thanks in advance
