System
CPU - Ryzen 2700
Gpu - gtx 1070 zotac amp extreme
RAM - adata xpg 3000mhz 16gb (2 8gb)
SSD - hp ex920
HDD - Firecuda sshd (x2)
PSU - thermaltake 700w
Motherboard - Asus strix gaming f x470
So for the about the last 5hrs I’ve been troubleshooting my pc because like the title says it won’t turn on, nothing happens when I push the power button on the case, gpu light doesn’t come on, no lights on rgb case fans, they don’t even spin, neither does the cooler fans for the cpu. Only thing that happens when I plug back in the psu power cord is that the aurora lights on the mobo and the standby power light turn on. I’ve tried resetting cmos, putting one ram in at a time, removing both, removing and putting back 24pin power connector to the mobo, removing gpu, ssd, hdd. After I while I decided to test the power supply with a paperclip and the fan on the psu spun so I left it for about 30secs then turned it off, tried plugging it back into mobo and same thing, just mobo lights up and nothing. At this point I’m lost as to what it could be, is my mobo dead?
CPU - Ryzen 2700
SSD - hp ex920
