• Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Discussion Is my power supply strong enough?
Apr 8, 2019
12
Hi All,
so recently I built my PC (about 3 days ago) everything was working fine for a day and then suddenly it stopped.
The problem is : No display at all
At first I thought it was the motherboard but then I got it looked at by a technician and he has advised that my graphics card has failed(card is about a year old) and he has tested it with a different card and it was working
below are my specs:
https://pcpartpicker.com/list/q9QmsZ
please tell me by experience or knowledge whether this power supply is strong enough fro this build?
Thank you
Mar 22, 2019
11
I guess you got just "enough", it's an ok PSU, components are good, but i think you should upgrade for something like 550 at least. Yet your card dying was probably just bad luck.
Reactions: CamerxnBxrger
Feb 28, 2019
169
7
85
Hi All,
below are my specs:
Thank you
You need to look at the PSU tier list, https://linustechtips.com/main/topic/1045610-new-psu-tier-list/?tab=comments#comment-12402695
your power supply is in the "just don't buy" section, a.k.a it's not the most reliable, the power supply is the most important thing in a computer, it dies your pc components might die too, or it'll kill itself only in which case you'd be lucky.
your psu should last a long time or could die tomorrow i couldn't tell you, just stay aware and upgrade to a more reliable and efficient psu eventually, it'll help you in the longrun, trust me.
Apr 8, 2019
12
cool thank you , I,ll take a look at that. at the moment i cant get a new PSU for about a month , will it be fine to use my PC until then?
Apr 8, 2019
12
DSzymborski
Glorious
Im just curious as to why the one i mentioned isnt any good
Because, like the Corsair VS, it's a basic entry-level power supply that uses low-quality capacitors and an old platform. Cooler Master PSUs tend to use third-tier (or worse) manufacturers for their PSUs until you get the high end; there's no budget Cooler Master I would recommend as a matter of course unless you were really down in the garbage tier.
Apr 8, 2019
12
oh i understand, does this PSU have peripheral/ molex cables as i need one fro my case fans ?
