Question Is my vg278hv asus monitor compatible with HP ENVY Extreme 12th gen?
I don't know. The Amazon page says nothing about it. The ad there gives you the option to buy a monitor that has HDMI, presumably because the two are compatible. I don't want to buy the computer and find out later that they don't work together.
Okay I'll make this easy for you. Assuming this is the model you're looking at or similar: https://www.amazon.com/HP-Extreme-12th-Generation-i7-12700K/dp/B0BG6DS7HC
Let's look at the back:
What I see is 1 HDMI port, 3 DisplayPorts, possibly a 4th one if you count the Thunderbolt connector.
Which inputs does the ASUS vg278hv take? According to the spec sheet, HDMI, VGA, and DVI.
Now which of these ports the two have in common? HDMI.
Ergo, you can use the monitor with the computer.
Reactions: David_652
