N nico6472 Reputable May 22, 2015 17 0 4,510 Apr 29, 2020 #1 Hi guys, I was wondering if my motherboard is compatible with the this cpu or do i need to upgrade to a newer? Hope you can help Sincerly Nicolai
rgd1101 Don't Moderator Nov 7, 2011 74,898 4,263 176,290 Apr 29, 2020 Solution #2 Nope. You can check it on the cpu supported list for the motherboard Reactions: nico6472 Upvote 0 Downvote Solution
N nico6472 Reputable May 22, 2015 17 0 4,510 Apr 29, 2020 #3 Thanks for the answer man appreciate it 😀 Upvote 0 Downvote
