[SOLVED] Is there a Compatible Bluetooth Dongle for Razer Electra Headphones
shadowking1984
30
I have an old Razer Electra Headset. The Sound Quality is still amazing and Recently the cable broke. Is there a Compatible Bluetooth Dongle that i can use avoiding any cables or are there any minimal cable options?
Any help will be much appreciated. Thanks in advance.
I have a razer headset which comes with a detachable 3.5 mm connector cable.Image of the headset. Will it be possible to pair it with an off-the-shelf adapter?
For a headset with both mic and headphone, a bluetoth adapter will transmit the headphone audio, the mic will be used from the bluetooth adapter. For just headphone use, there are several good quality bluetooth adapters that can turn any headphone into a bluetooth one. Just keep in mind the microphone audio will be going through the bluetooth adapter not the headset mic.
Something like this...
Which one do you have? The USB driven headset or the analog driven headset? If either of them, you can try and repair the cables, although they won't be the best of looking headset cables(unless you use some sleeving and heatshrink and patience) but there's no option to have that headset tethered to a BlueTooth adapter unless Razer have a wireless version that was released without much marketing. In the likely event that there's a wireless version, given how Razer is, I doubt you could pair it with an off-the-shelf adapter.
Something like this https://www.amazon.com/Comsoon-Cancelling-Headphones-Hands-Free-Connect-Black/dp/B094FVLHGV/ref=sr_1_11?crid=U7BIUZSXHQUZ&keywords=mpow+bluetooth+adapter&qid=1644527778&sprefix=mpow+bluetooth+adapter,aps,75&sr=8-11
I use a similar model to this, higher quality with a built in amp and a decent DAC but more expensive https://www.amazon.com/FiiO-BTR3K-Bluetooth-Headphone-Unbalanced/dp/B085XT3V3X?ref_=ast_sto_dp This is a cheaper bit older model that I own https://www.bhphotovideo.com/c/product/1380304-REG/fiio_btr1_bluetooth_headphone_amp.html/qa?ap=y&ap=y&smp=y&smp=y&lsft=BI:514&gclid=Cj0KCQiAjJOQBhCkARIsAEKMtO3ok3zEi-KHrbip0m9_gpz6xwV5ug4UhNg1HqVi6CaGHd7kdCcf4sgaAjcrEALw_wcB
If you don't mind the wait and dealing with shipping from China there is this model, which is good quality and decent price for what it is https://www.aliexpress.com/item/400...&terminal_id=ae2aed74e7d84313aa98cd22fccd0eac
