Is there a converter from coax to Ethernet plug
G
Guest
Guest
Hello,
Is there a converter from coax to Ethernet plug. I have FIOS router and want to replace it with a net gear router
The input to the FIOS router is a coax but net gear router does not have a coax input
You cant just get a cable converter for that, you need a modem that communicates with your isp through the cable connection. If you want to use the netgear just plug a cable from the wan port on the netgear, to one of the ethernet ports on the FIOS modem/router.
