Hello,
i had a pre built pc with Components that are not bad so i wanted to build a pc for a colleague using those components. As i've got done with everything except storage, i noticed that the power supply didn't have a single power cable except the CUSTOM power cable for the motherboard and also the 4 pin for the motherboard (really weird i know). Now because i can't get any other power supply because of the motherboard's custom power cable i thought i could ask here if there's a way to connect a HDD power cable or the HDD itself with having the same speeds as connected directly to motherboard.
I hope you understood the problem, my english is not so good.
Thank you
Thank you
