[SOLVED] Is there a way to turn off the green LED on an rtx founders edition card?
Mrgr74
Upstanding
Sep 2, 2019
304
67
290
21
There is software you can have that will disable the RTX RGB. Take a look here: - RTX RGB I have this installed and it works great. Even if your GPU isn't an EVGA card, it'll still work. (You can do a ton of other stuff with X1 as well and not just turn off your RGB, like set your fan speed for example.)
EVGA Precision X1 - https://www.evga.com/precisionx1/
Mrgr74
Upstanding
Sep 2, 2019
304
67
290
21
