[SOLVED] Is this correct for front panel connectors?
ironcreeper2004
145
The board in the picture is a B450 Steel Legend MATX. On the far left I've connected the cable labeled "USB" there, on the far right I've connected the PLED+, PLED-, HDLED+-, PWR and RESET. The PLED plus and minus are in the top left, the HDLED+- is in the bottom left, the PWR is in the top right and the RESET is in the bottom right.
https://ibb.co/F8xDPB1
Sorry if I didn't describe this well, thanks for any help.
Matching your description to the manual it sounds right
It doesn't say which pin is for the + or - for the PLED (power indicator light) but worst case scenario the power indicator won't work and you'll just have to move the connector to the proper + and - pins
