Hello.
I'm thinking about buying a VR Headset I'm between buying a used Oculus CV1 from ebay or an Oculus Quest from Amazon.
I'm wondering if I could run games alright with my specs that I have right now or if I should spend my saved money better on a new GPU or RAM, I've read that Oculus has a feature where it sync's the frames to 45 it's called ASW 2.0 does that make it better?
I don't care about playing games on the highest settings, as long as I can run them well without too many FPS spikes/drops to the point where it would get uncomfortable to play
The games that I'm likely interested to play are.
Half Life Alyx
Boneworks
Interkosmos
Pavlov
Lone Echo
Echo Arena
Subnautica
Alien Isolation
Beat Saber
PC Specs:
CPU: I7-3770 (non k)
GPU: GTX 970 (stock non oc)
RAM: 8GB (1600mhz)
PSU: Corsair VS550
Motherboard: ASUS P8H61-M LX3 PLUS R2.0
If anyone here has similar specs with mine and has tried some VR titles, I would appreciate reading the feedback.
Thank you for your help in advance (also small note, I'm planning to use it on USB 2.0 since Oculus Link supports it now, I don't know if it makes a big difference)
www.roadtovr.com
Half Life Alyx
Boneworks
Interkosmos
Pavlov
Lone Echo
Echo Arena
Subnautica
Alien Isolation
Beat Saber
PC Specs:
RAM: 8GB (1600mhz)
PSU: Corsair VS550
Oculus Quest Can Now Tether to PC with Its Included USB 2.0 Cable
Oculus Quest can function as a PC VR headset with the Oculus Link feature which was introduced in beta late last year. At launch the feature only supported USB 3.0 cables, which somewhat awkwardly didn’t include the cable that came in the box with Quest. A recent update to Oculus Link now allows...
