Hi!
I wanted to ask if someone has any input on an issue that I have with my Phanteks Premium DRGB Lighting Kit for the Phanteks NV5 Mid-Tower Case.
The LEDs kind of flashes, some parts more than others. The behavior changes over time, after rebooting only some parts of the LED is flashing but after a while more and more of the strip starts to flash. I've checked all the connecting cables and they look good, nothing changes when trying to "joggle" the contacts to see if there is a connection issue.
I'm wondering if it's worth trying to replace the LED kit or if the problem might be something other then that?
For reference, this is the LED:
phanteks.com
And I'm using this moderboard:
rog.asus.com
Here is a video of how it looks:
Any input and pointers on things to try would be very much appreciated, thanks a lot!
Phanteks Premium D-RGB Kit – NV5 | Black
The NV Premium D-RGB Kits designed specifically for NV chassis. Elevate your NV chassis with mesmerizing lighting effects with the included D-RGB LED modules that securely mount on the outer frame of the NV.
ROG STRIX B650E-F GAMING WIFI | ROG Strix | Gaming motherboards|ROG - Republic of Gamers|ROG Global
The ROG Strix B650E-F Gaming WiFi takes you to the future with 12 + 2 power stages, hyperspeed DDR5 memory, and next-gen PCIe® 5.0 connectivity. It is equipped with three M.2 slots with heatsinks, a USB 3.2 Gen 2x2 port, WiFi 6E, AI Networking, Two-Way AI Noise Cancelation, and Aura Sync RGB...
