Around two weeks ago, I decided it was time to build a new PC. After looking around a bit, I decided on these specs:
This is my second PC build. My previous build was an FX8320 on a 970A-G43 motherboard (+ GTX 960) and went pretty smoothly.
However, after putting together the components on the PC, it wouldn't post (no picture on screen, keyboard not working/lighting up) and I could see the yellow DRAM error on the motherboard.
At this point, I spent the day troubleshooting and wondering what I should do. It was here where I discovered the label on my motherboard box saying "compaitable with Ryzen 2000 CPUs", implying that the board had not yet been updated by the manufacturer.
So, I decided that I had two options to fix the machine:
So, I decided to go with the latter, and spoke to ASUS representatives for hours and hours, eventually getting confirmation that they could not replace my board and so I'd need to request the boot kit from AMD. During this time I also requested a QVL memory list for my motherboard for Zen 2/Ryzen 3000 processors, however it seems one is not yet available.
Yesterday, the boot kit arrived (Athlon 200GE) and I installed it on the motherboard. The CPU has integrated graphics and AM4 motherboards have HDMI ports so I didn't bother installing the GPU. After powering on the system again (and clearing the CMOS!) I was still getting the DRAM error!
At this point I was absolutely convinced it was time to give some new RAM a go, so I ordered some more RAM which is quoted on the QVL lists for:
In the post today I'm getting the "HyperX HX432C16PB3K2/16 Predator DDR4 16 GB (Kit 2 x 8 GB), 3200 MHz CL16" (quote from Amazon)
before anyone replies with these answers I've tried already, I've:
So at the moment I'm waiting on my delivery for another kit of RAM, and am hoping/praying it will boot.
So yeah, feels great when you are sent a boot kit... And then can't even boot with the boot kit. This is quite a lengthy post/question, and if you can't tell already I'm running out of ideas (and money!) so any help would be massively appreciated
Cheers ~ Tom
- Ryzen 5 3600x
- ROG STRIX B450-F GAMING Motherboard
- Corsair Vengeance RGB Pro dual-channel 16gb DDR4 3200MHz
- MSI RTX 2060 GAMING Z.
- Spend another £80 on RAM which might not work.
- Contact ASUS/AMD about the issue and get my hands on a boot kit to update the BIOS.
- My motherboard (Ryzen 1st gen)
- My motherboard (Ryzen 2nd gen)
- The motherboard model below mine (ASUS PRIME b450f PLUS) (Ryzen 3rd gen) since there is not yet a QVL list available for ryzen 3rd gen for my motherboard.
- Used RAM slots A2/B2
- Cleared the CMOS
- Reseated the RAM
- Tried two different power supplies (EVGA 500W from old PC and new Corsair cx550)
- Tried individual stick of RAM in each slot
- Later today I'll install the new RAM onto the motherboard with the Athlon 200GE processor, let's see if it posts...
- If it doesn't, it may be worth a try swapping the Athlon for my r5 3600x just to make sure the Athlon processor isn't being awkward.
Cheers ~ Tom
