Question Issues with GTX 1650 (GIGABYTE WINDFORCE OC, 4gb GDDR5) please help!
4
Tech Support
Pc specs : GPU GTX 1650 windforce OC gigabyte Cpu core i5 9400f Psu ant eSports 650w (it's not the issue of psu because I replace my GPU with someone else's and it works fine) Motherboard gigabyte b450 Ram vengeance 8gb ddr4
issue:black screen( HDMI display conection going off and fans ramp up to 100%) (November 2023)
So in march of this year 2024 I decided to run a DDU with my backup card gt 730 and then put back my 1650 , When I did plug in the 1650 and tried to turn on the PC it never turned on , no lights no movement nothing just pure silent . From what I remember from my memory is that one of the HDMI slot was kinda brokey and when I did plug the HDMI cable into that the pc dosen't turn on but on other slots it does , Now my stupid mind forgot to do that while I did the DDU day before yesterday ( Iam now back using the gt 730 ) , So I was wondering would a faulty HDMI connection block the pc from turning on ?
Here is the video of what happened during november 2023 and forward
warranty expired on august 2023 ( RAHHHH)
View: https://youtu.be/JuZhO0npYww
Like I mentioned I had once a problem where one of the HDMI slots of the GPU didn't work and the pc didn't turn on because of that but the other slot did , when I did DDU I plugged it into the slot where it was broken I believe , Do you know why this happened?
May work it’s really easy just look up a tutorial, I do believe your gpu may be dead though and as you mentioned you unfortunately cannot rma
