Issues with Monitor - Need Help
RandomRestore
Commendable
May 23, 2016
5
Alright, so I'm a first-time PC builder and I've got a problem. My monitor is a VGA monitor that is attached to the mobo VGA port. Everything works fine and dandy and my system POSTs. Now, I add my GPU in(and no monitor is attached to it). I boot up the system, "No Signal". Is this normal, and is the way to fix this is by plugging in a monitor into my GPU? Let me know thanks.
Also, my GPU only has DVI and HDMI ports, 1x DVI-D, 1x DVI-I. I have two VGA monitors and I am looking at a converter. Can I only use one converter, as I only have one DVI-I port?
Also, which converter do I get? VGA to DVI-I or VGA to DVI-A.
And finally, would there be a problem with me having one monitor in the mobo VGA port and the other one in the GPU DVI port? I don't plan to game or video edit with two monitors, just going to use the second monitor to manage my background applications when I'm gaming(as most games go fullscreen). I want my OS to utilize two monitors.
Also, if this makes it easier, the monitor I intend to plug into the GPU has something called "DVI(optional)" in the instruction manual. However, I've looked through the monitor 20 times and there isn't a DVI port.
Here are my parts:
PCPartPicker part list: http://ca.pcpartpicker.com/p/ccfnTH
Price breakdown by merchant: http://ca.pcpartpicker.com/p/ccfnTH/by_merchant/
CPU: AMD A8-6600K 3.9GHz Quad-Core Processor  (Purchased For $110.00)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (Purchased For $37.00)
Motherboard: MSI MSI A88XM-E45 Micro ATX FM2+ Motherboard  (Purchased For $0.00)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1600 Memory  (Purchased For $35.00)
Storage: Seagate Barracuda 7200.10 80GB 3.5" 7200RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: EVGA GeForce GTX 760 4GB Dual FTW ACX Video Card  (Purchased For $140.00)
Case: Silverstone TJ09-BW ATX Full Tower Case  (Purchased For $60.00)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (Purchased For $103.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $0.00)
Total: $485.00
Generated by PCPartPicker 2016-05-29 12:09 EDT-0400
Monitor for GPU is a old 2010 or 2012 eMachines monitor.
Monitor for background applications is a 2006 ViewSonic monitor.
Thank you for listening to my nonsense for the past 5 minutes. I appreciate all answers, thank you!
I know that, but my monitor uses a VGA cable, and the gtx 760 doesn't have any. Would it work if I used a VGA to DVI-A converter?
