Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi All,
I have a 1 month old K8V SE Deluxe and Antec SX1040-II case. This
combination works really well and the extra cooling fans are a nice bonus.
However I have 2 problems which I'd like a little feedback on before I raise
it with the vendor:
1. The PSU has a sense wire for the motherboard so I can detect/monitor the
PSU fan speed. This doesn't work. In fact, no fan I plug into the
motherboard's "Power Fan" connector detects the speed. Yes, I'm using fans
with the sense wire that I know work - I can get a fan speed using the
"Case Fan" connector on the same motherboard. Have I missed some funky
BIOS feature or do other people have problems with this too?
2. The front FireWire connector doesn't work at all. Nothing I plug it into
the front FireWire port is detected. The USB2 connectors work, and yes,
I've tested the FireWire devices on the hard-wired connector on the back -
success
Seems the wiring for the front FireWire port on my Antec case
might be wrong. The K8V came with an extra bracket+lead for a 2nd rear
FireWire port - this one works fine. Just the case FireWire is screwy.
Any ideas folks? Looks like the mobo power fan sense is fubar, but I might
be able to re-wire the case's FireWire connector. I'd really prefer to
keep the case, it took me ages to wire everything up nice and neat. The
mobo OTOH I can swap in-and-out relatively easily.
Cheers,
James
If you're going to do something tonight that you'll be sorry for
tomorrow morning, sleep late.
-- Henny Youngman
Hi All,
it with the vendor:
success
Cheers,
James
-- Henny Youngman
