Hi everyone, giving toms hardware a shot to see if we can help solve my issue.
PC Specs:
GIGABYTE X570 AORUS ELITE WIFI ATX AM4
RYZEN 7 5800X 3.8GHZ 8 CORE
EVGA XC3 ULTRA GAMING GEFORCE RTX 3070
CORSAIR H11i RGB PLATINUM 97 CFM LIQUID COOLER
RAM: CORSAIR VENGEANCE RGB PRO 3200 2X16 DDR4
PSU: CORSAIR RM 750
Okay before we discuss the KERNEL POWER 41 issues that I have, please note that
the BIOS is from 2022 (apparently there is a compatibility issue between the motherboard and cpu, but that's only if you don't have at least BIOS VERSION F30 which I'm almost certain I have above.
-Kernel power 41 developed out of no where!
-I reseated my ram
- Kernel power crash happens usually after 30 minutes of gaming, and I DO NOT BSOD.
-Happens even when ram is at stock
-PSU is 2 years old.
-I play on a 31in 1440p 165 hz monitor, not sure if monitor size and refresh rate matter here
-PC makes it warm in my room
-Should i be getting stable frames and a flawless gaming experience with this setup? Ive also used driver booster to update every driver.
Here's where I'm at.
I try to run most my games 1440p, and 145 fps. Im getting the fps, but my nvidia gpu stats say that my "99% fps" is like between 40- 70 with stutters ( i think?). It sucks cause it "works" but at the same time it really bothers me when my games look like <Mod Edit> and not super nicely like everyone else i know.
I've been trying to game for the last few months, but i find myself turning all my settings down just so I can have a somewhat smooth experience. I waste most of my time tuning these setting and end up barely having time to play. I just want to come home from the hospital and be able to game![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Im nervous to replace all my hardware when i know it could be a simple issue
I would love if I could have my hand held through this. I should be able to send all speeds, times, voltage, and whatever we need to help solve my issue! I should be around later tonight to send this info along.
PC Specs:
PSU: CORSAIR RM 750
-I reseated my ram
