So basically im heaving this trouble since i bought my Pc (October 2019) and im having those problems since day one. It was a Alienware PC and the power supply (it was in a constant bootloop) was failing so i moved the internals to another case and replaced the PSU, unfortunately the problem still presisted, it wasnt as bad as the Alienware PC though, i could browse normally. But when i Play games (i play Rainbow Six Siege, Escape from Tarkov, Assassins Creed Unity) in all games it crashed, i played a game that is not so demanding and it worked. I am really frustrated because i have not the knowledge to find a fix and i have been researching alot but still couldnt find the solution.
What i tried:
Replacing PSU
DDU' the GPU
Replacing the CPU Cooler
Turning off Turbo Boost mode (it helped a bit by delaying the reboot)
Specs:
OS: Windows 10 Home 64-bit
CPU: Intel Core i7 960 @ 3.20GHz
GPU: 4096MB ATI AMD Radeon R9 Fury Series (ASUStek Computer Inc)
RAM: 20.0GB Triple-Channel DDR3 @ 668MHz (9-9-9-23)
Motherboard: Alienware 0XDJ4C (Intel x58)
SSD: 223GB SanDisk SSD
HDD: 3726GB Western Digital WDC WD4000FYYZ-01UL1
i really hope someone can give me a solution to this, it is very hard to find the problem because it could literally be everything. It has tormented me for the past months. Maybe i can expand my knowledge more with your help too!
Thank you in advance!
What i tried:
Replacing PSU
DDU' the GPU
Specs:
