KT-400 Dragon Ultra Platinum- RAID problems
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.soyo (More info?)
Hi. I am trying to set up RAID 1 on a brand new KT-400 Dragon Ultra Platinum
MoBo. 2 160Gig Seagate drives, Both master, one on IDE3, One on IDE4, Both
brand new raw drives, no partition. Have been through the bios multiple
times, when the RAID controller is enabled (Highpoint controller onboard),
and you go to set up the RAID array with <ctrl>+<h> the RAID controller BIOS
does not come up. If you remove both drives you CAN get into the RAID setup,
of course you can't do anything as no drives are connected. Do the drives
have to be partitioned first or have I got some kind of goofy conflict going
on. I was wanting to set up RAID, then install windows XP. I have an Athlon
XP2500+, 512MB DDR333, and a NVIDIA AGP card. Everything else is built on
the board, nothing in any PCI slots. Any help appreciated.
Set both drivers to CS (Cable select).
Daniel
"Ampdoc" <ampdoc@NOSPAMhotmail.com> wrote in message
news:0wrbc.16893$xW1.13550@bignews4.bellsouth.net...
Platinum
BIOS
setup,
going
Athlon
Thanks for the reply. I tried that with no success.
"Midnight" <Midnight@Midnight.com> wrote in message
news:dPednUWhZvDcAPPdRVn_iw@comcast.com...
> Daniel
> Platinum
Both
onboard),
> BIOS
> setup,
drives
> going
> Athlon
on
Are you puting each drive on it's own IDE port? Have you tested the drive
on the onboard standard IDE to ensure you don't have a faulty drive? Check
to be sure the drives are plugged all the way in. I had a drive that
appeared to be plugged in, but I found out later that it one of the little
medel posts pushed back and didnt' plug in. Also check to ensure that you
don't have one of the pins bent when you plugged in the rybon cable. And
also double check that you didnt' somehow accidently plug in the rybon cable
backwards.
Daniel
news:42zbc.1213$FX.147@bignews2.bellsouth.net...
> > Daniel
> > Platinum
> Both
multiple
> onboard),
controller
> > BIOS
> > setup,
> drives
> > going
> > Athlon
> on
Hi. Answering back from work. Problem was the BIOS. it had KV7VX4-2AA4 bios
originally, flashing the latest BIOS allowed the Highpoint controller to
"see" the 160 gig drives correctly. Thanks for your help.
Ampdoc
news:uNmdnYswroMdZPPdRVn-tw@comcast.com...
Check
cable
> backwards.
> Daniel
> > > Daniel
> > > Platinum
IDE4,
> > Both
> multiple
> > onboard),
> controller
> > > BIOS
RAID
> > > setup,
> > drives
conflict
> > > going
> > > Athlon
built
> > on
I was wondering about that, was going to be my next suggestion. Glad to
hear all is good... Take care.
Daniel
"James" <James@notmyrealaddy.com> wrote in message
news:nzDbc.4598$6D1.2375@bignews5.bellsouth.net...
bios
> Ampdoc
drive
> Check
little
you
And
> cable
> > backwards.
> > Daniel
> > > > Daniel
Ultra
> > > > Platinum
> IDE4,
> > > Both
> > multiple
> > > onboard),
> > controller
> > > > BIOS
> RAID
> > > > setup,
> > > drives
> conflict
> > > > going
an
> > > > Athlon
> built
> > > on
