There is room in my laptop for an mSATA drive, but one of the cables for the fan appears to be in the way, I have attached an image with the cable circled in red.
The cable can be seen stopping the mSATA drive from attaching to the motherboard correctly.
I am able to move the cable underneath the drive, but this solution leaves the cable pushing up against the drive, as seen below.
Is it a problem that the cable presses against the underside of the drive? If so, is there some other way for me to overcome this issue? I've noticed that a few cables appear to be coming from the fan region, is it necessary to have them all plugged in?
Specs:
Laptop
Model: MSI GE60 0ND
Motherboard model: MS-16GA
SSD: Samsung V-NAND SSD 860 EVO mSATA
Specs:
Laptop
Model: MSI GE60 0ND
