hell_storm2004 Splendid Nov 23, 2009 3,645 2 23,165 Aug 31, 2010 #2 That depends on the chip you select. For Intel Check this: http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors ^^Since this is a huge list, just check the Core i5, i3 and i7. They are the latest. On the AMD side: http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors Upvote 0 Downvote
Herr_Koos Splendid Jul 14, 2009 5,020 0 26,460 Aug 31, 2010 #3 Dear George, The latest desktop CPU's can run all the way up to 3.4 or 3.6 GHz. You also get multiple cores per processor, which actually means several processors running at that speed. Hope this helps. Upvote 0 Downvote
S stoky75k Distinguished Aug 31, 2010 1 0 18,510 Aug 31, 2010 #4 CPU cache is olso a great factor. There are L1-L2-L3 cache on your procesor wich greatly improves performence when it comes to reading the same data. Upvote 0 Downvote
unknown_13 Distinguished May 12, 2009 1,539 0 19,860 Aug 31, 2010 #5 Architechture, cache, QPI/DMI/FSB/HT freq. and the number of cores are a lot more important for CPU's nova days. To answer your question, i think the highest stock CPU freq. is 3.4GHz (the PII X4 965). Upvote 0 Downvote
G ganesh pawar Honorable May 30, 2012 2 0 10,510 May 30, 2012 #6 Hello, what is the latest speed of processor Click to expand... I don't know Upvote 0 Downvote
G ganesh pawar Honorable May 30, 2012 2 0 10,510 May 30, 2012 #7 Hello, what is the latest speed of processor Click to expand... I don't know Upvote 0 Downvote
