jaguarskx Titan Apr 19, 2006 27,978 3 84,965 Jul 30, 2010 #2 It depends on the specific model and best for what? I generally tend to focus my knowledge on larger size / higher end monitors so I probably will not be able to recommend anything to you. Click the following link for info about LCD monitors; they also have a few reviews: http://www.tftcentral.co.uk/specs.htm Upvote 0 Downvote
Emperus Splendid Aug 10, 2008 4,096 1 23,460 Aug 2, 2010 #4 Both monitors will be mostly based on a TN panel and so would give out similar color performance and picture quality.. You can safely get the one which looks best to you.. Personally though, i'd rate samsung displays a notch above viewsonic.. Upvote 0 Downvote
