Whenever i reboot my PC the LED backlight setting resets to the default setting. Is this normal for redragon karura2 K502 keyboard? or is there a way yo save the LED setting?
I checked the redragon website, they dont have any app for this model. I think they do have a kind of control app for different model keyboard but not this.How do you go about putting the LED lighting back the way you wish it to be?
Is there some app or control panel like window? Any configuration windows for the keyboard?
Likely to be a save option available that will put the settings in a file that, in turn, would be used to restore the settings versus you having to retype everything.
There could also be an option that uses the saved file as the source for default settings.
Overall, I am not sure that the K502 supports saving the configuration settings. I visited the website and found references to "Red Impact" but that seems applicable to the mice.
Then every time i boot my PC i need to run this. I think buying this keyboard is a very bad decisionI checked the redragon website, they dont have any app for this model. I think they do have a kind of control app for different model keyboard but not this.
So everytime i reboot my PC i need to manually change the LED setting by pressing the keys they gave on the keyboard
