Hi guys! And thanks in advance! =)
Short long story:
I bought Led Lights in Aliexpress for my pc. I tried to install them with the PC turned off. It was a 5050 12 v of my mobo, Msi B450-a Pro (2600 Ryzen, 8GB Ram Predator Hyperx, 2060 Gtx Zotac, etc).
Then i turned on. Everything's go fine.
But the piece did not fit very well. It moves a little when i was manipulating to install it into the case. So, with the PC Turned on, i pushed to fit the Led into the Mobo 4 Pins because the ligths turned of...
The PC started to reboot 3 times in a row. I turned off. I was scared... omfg XD
And now it can't boot. I can't see the Bios, nothing. The Led light of the Mobo is turned on all the time and the PC have tha fans running, the original Led light, and so on, but can't boot.
I disconnected the PC, and removed my 2 Ram Sticks. Tried 1 in every slots, tried dual channel in the other bays, nothing. It can't boot. Pushed the Bios Reset button, nothing. I left the mobo withouth the battery to reset bios, nothing.
It can't boot and all the time the white Led of the VRam on, and can't boot.
So now i'm wondering if it could be the mobo or the ram damaged... I think it's very rare the Ram is damaged, i think it was my fault
for MANIPULATING THE RGB CONNECTOR OF THE MOBO WITH THE POWER TURNED ON...
AND I BROKE SOMETHING... Sorry for the caps...
I didnt know that this things could happen. ¿Should i buy a new mobo? ¿Or maybe buy new Ram to test it?
I feel so stupid... 🙁
And thanks for the help.
Short long story:
