Linux and Acard AEC-6897 PCI-X ATA controller?
G
Guest
Guest
Archived from groups: comp.os.linux.hardware,comp.sys.ibm.pc.hardware.storage (More info?)
I'm in the market for a four-channel PCI-X 64-bit ATA (not SATA)
controller card
(<URL:http://groups.google.ca/groups?selm=slrncvkvig.phj.ylee%40pobox.com>)
and was referred to the Acard AEC-6897. However, there's no
information on whether this will work with the Linux 2.6 kernel,
specifically for software RAID. Anyone with firsthand experience, good
or bad?
Read my Deep Thoughts @ <URL:http://www.ylee.org/blog/> PERTH ----> *
Cpu(s): 4.2% us, 1.6% sy, 93.7% ni, 0.0% id, 0.0% wa, 0.3% hi, 0.3% si
Mem: 515800k total, 513516k used, 2284k free, 51720k buffers
Swap: 2101032k total, 124796k used, 1976236k free, 127408k cached
> controller card
> or bad?
If it works for individual drives, then it works for software
RAID. The potentially negative effect I know of is bad performance, as
IDE has some troubles with two drives on one channel being used
simultaneously.
There is support for Acard AEC62xx (Artop ATP8xx) controllers in
the 2.6.10-as2 kernel. Whether they are compatible with your cards,
I have no idea and the driver source files are unhelpful.
The AEC webpage lists Linux Support as "comming soon", so it likely
is not there yet. Still, generic IDE support and the more specific
AEC driver may work both or fail miserably.
Maybe you should get two Promise 100tx2 or 133tx2 in the meantime
and wait a bit for a PCI-X solution. If you put only one disk
in a channel, the promise controllers are pretty fast and work
well under Linux. They also work in pairs, with one BIOS then
controlling both cards on boot-up. (Later the kernel takes over.)
Arno
For email address: lastname AT tik DOT ee DOT ethz DOT ch
GnuPG: ID:1E25338F FP:0C30 5782 9D93 F785 E79C 0296 797F 6B50 1E25 338F
"The more corrupt the state, the more numerous the laws" - Tacitus
