Liquid Cooling for GTX 680 and I7 3820
VANISH048
Hey Guys,
So this is my build so far:
Intel I7 3820 Quad Core:
EVGA GeForce GTX 680 SC Signature2:
KingWin Lazer Power Supply 1000 Watts:
ASUS P8Z77-V PRO:
16gb Crucial Ballistix Smart Tracer RAM:
128gb Crucial m4:
Raid 1 WD Black 7200rpm 500gb:
Lite On DVD Drive:
LG Blu-ray Drive:
So thats my build, the case is custom built. My question is i want to liquid cool the CPU and GPU. I'm looking at these parts so far but my question is will the 2 x 120mm radiator be good enough to get rid of the heat or should i put two radiators or maybe even do a two loop.
Ok just adding to my question here how powerful does the pump need to be what is the min. flow rate i should have since im going through a CPU, GP, Radiator and Reservoir.
PUMP: http://koolance.com/pmp-500-pump-g-1-4-bsp
CPU BLOCK: http://koolance.com/cpu-370si-processor-water-block
GPU BLOCK: http://koolance.com/vid-nx680-video-card-vga-nvidia-geforce-gtx-680-water-block
RESERVOIR: http://koolance.com/reservoir-pc4-rp-1000-10mm-3-8in-id
RADIATOR: http://koolance.com/radiator-2-fan-120mm-30-fpi-copper
I haven't thought about fans or other stuff yet. I'm also not looking for completely low temperatures.
VANISH048
At kitsunestarwind
sorry mate put the wrong board thats my brothers computer board mines the Asus P9X79
But thanks for the reply, so i've decided to go with the 360 rad will a pump with 8.7L/min be strong enough.
